Use consistent hints and naming in menus for Ctrl-T to open a Table
2278
6
08-04-2024 05:21 PM
Status: Implemented
RTPL_AU
Edited Idea:
Opening a Table and opening an Attribute Table is the same thing for all intents and purposes.
Standardise Pro to use the same naming and shortcut hints for Ctrl-T to open Tables as well, not just Attribute Tables.
Geometry layer:
Table:
This will make it easier for new users and those that use a lot of different tools.
6 Comments
AlyciaRajendran_esri
Hi! This is currently offered. If it is not working for you, please contact Support so they can help you figure out what's going on. Thanks!
RTPL_AU
@AlyciaRajendran_esri
I was going by the lack of shortcut text next to Open:
Please be consistent with naming things in Pro. Do you want me to update this Idea to revise and describe it as a UI change or make a new Idea?
You're completely right, @RTPL_AU. We will fix the inconsistency. It would be very helpful for you to revise this Idea, so others can find it easier. Thanks for bringing this to our attention!
Bud
KoryKramer
The built-in shortcut has been added to ArcGIS Pro 3.4.
For the question of attribute table vs. table, see https://community.esri.com/t5/arcgis-pro-ideas/consistent-terminology-fc-gt-gt-attribute-table-vs/id...
Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
