Unzip/Zip Files in ArcCatalog
5707
07-21-2013 03:21 AM
Status: Closed
Carlynneworsham1
.Zip and .rar files should be recognized by ArcCatalog so user can zip and unzip from within ArcCatalog rather than unzipping first so the files may be viewed in ArcCatalog.
Tags (1)
3 Comments
curtvprice
You can add file types using the ArcCatalog application options (files tab), including zip. If you do so, they appear in ArcCatalog and ArcMap's Catalog window. If you double click the zip file, it will open using the windows file association for .zip (Winzip for example).
This doesn't exactly do what you want but it is close. I think it would be neat if ArcCatalog could look inside zipfiles and access their contents read-only directly.
BruceHarold
Data Interoperability extension can 'see' into ZIP files and also write file-based formats into ZIP files.
AletaVienneau
Status changed to: Closed
ArcGIS Desktop, which includes ArcCatalog, retired March 1, 2026. Therefore we will not be considering this idea for ArcCatalog.
A similar idea was written to request support for data stored in ZIP files in ArcGIS Pro (as well as ArcCatalog): https://community.esri.com/t5/arcgis-pro-ideas/look-inside-zip-files-and-access-zipped-content-in/id.... Consider adding a kudo or a comment to this other idea.
We truly appreciate your contributions that help us continuously improve the software to help you do your work. We look forward to hearing about your ideas about how to improve ArcGIS Pro.
