Unselect individually only one graphic item on clicking on it again
3657
02-13-2022 04:26 AM
Status: Already Offered
GregoireS
Often in a complex layout we have to select many graphic in same time to apply some modification on them (moving, deleting...). Very often i do a mistake and select an other item which i shouldn't. Or it's just much faster to make a rectangle selection and unselect some items individually.
If i'm not mistaking, there is no possibility to unselect it individually by clicking on it again. Then i have to unselect all and start again, which is quite painful.
4 Comments
DanPatterson
So you are proposing an addition to this? or none of these work for unselecting?
Keyboard shortcuts for working on the layout—ArcGIS Pro | Documentation
GregoireS
Correct, none of these work for unselecting individually, and all are keybord shortcuts. I want to just left-click on the element i want to unselect, as it works in ArcMap.
KoryKramer
Hold Ctrl and click on an individual element to unselect it without having to unselect all and start over again.
 Holding Shift and clicking should add to selection. Holding Ctrl and clicking should remove from selection.
GregoireS
Oh right, yes, thanks
