Temporarily save the .mxd Project with the same file name.
602
12-21-2015 08:39 AM
Status: Already Offered
MarcosSerpa
Fellows, i usually work with .mxd projects and from one or more procedures steps, the ArcGIS simply stop working and appear that advise "not answering" so i loose the project since the last time i saved it. And also, sometimes, really often, i am going to save the .mxd project and appear an advise saying that i can not save that project with the same filename that it is and i have to create another filename dor the .mxd, so i have a lots of files (.mxd) with different names and small differences. What i would like arcGIS to have is the possibility of choose a periodicy of saving the .mdx projects automatically and also to save this files (.mxd) with the same name it is the actual filename! I appreciate if i can don´t loose my projects and to don´t have so many almost equal files with different names! Thank you!!! Marcos CS.
1 Comment
NaicongLi
This capability is already offered in ArcGIS Pro.  By default, an ArcGIS Pro project is automatically backed up every 5 minutes, but you can adjust this frequency in the Options dialog box, General tab:
Here is the Help topic regarding how we support backups for ArcGIS Pro: https://pro.arcgis.com/en/pro-app/latest/help/projects/save-a-project.htm#ESRI_SECTION1_090E953C44C5...
If you need to save different versions of the project, you can do so via Save project As, in the backstage of the the current project.
Thank you for your feedback.
