Table Optimizer/Restructure Tool
1577
12-03-2012 09:25 AM
Status: Closed
ErinLeFevre4
It would be great if there was tool that would allow you to restructure and optimize an existing table/feature class.
Tool options:
  • Change Field Type & Field Properties
  • Change Field Name
  • Change Text Case
  • Add/Delete/Import fields
  • Optimize Utility checks for errors and makes suggestions on  more appropriate Field Type
  • Accept/Modify/Deny changes and export new table/feature class
2 Comments
ReeseHirth
I would also like to permanently move a field's location in the attribute table.  ET GeoWizards has a tool that does all of these.  In addition, I would like to have the tool be able to run in Model Builder.
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to open, duplicate Idea.
