Table Frame
701
06-04-2024 02:44 PM
Status: Open
Elan_Echevarria_Marin
Would it be possible to add the ability to edit table frames in future versions? For example, to be able to add a title to the table and make modifications such as adding new columns, in order to make the table more manageable and not just what is available by default. Thank you for your help.
Tags (1)
2 Comments
AubriOtis
Hi! Thanks for the idea. Have you tried different fitting strategies for your table frame to help with the columns? Each fitting strategy lets you do different things, and other things are automatically updated. For some you can select the number of columns used in fitting the table frame to the bounding box. Learn more in the fitting strategies section of the table frame help topic.
Hello, Tables.pngThank you for your suggestion, but the idea I have is to be able to make changes to the columns, such as being able to split a column into two only in the upper part, as shown in the attached image. I used to use Crystal Reports to make that kind of change.
