Table formatting based on a different definition Query
807
07-28-2022 07:08 AM
Status: Closed
RobertBorchert
Honored Contributor
What I would like to see as part of a definition query is a separate query that will result in custom formatting of the attribute table.
As an example.  I have a Look Up Table of Substations and busses for use in matching up Arc flash and grounding data.  As new locations are added to the feed I need to update the LUT with a location number and the data source Join Field.
What I would like in the LUT after adding the new locations have those rows where the  Location is  Null in the join be highlighted a different color.
This way I can go through my LUT, which currently has 1200 entries, sort them Alphabetically based on the Name  and easily see those without a Location number.
Yes, I could definition query out to only show those without a Location or Select by attributes.
Something like the below image.  In this example I need to add BlackLake_12.47 to the LUT. It is actually the same location as BlackLakeD_69 but just a different voltage.  All I would need to do is transcribe the Location number.
3 Comments
KoryKramer
Thanks for submitting this idea @RobertBorchert I think we need some more info to better understand the request.
You refer to an image, but I don't see any image posted. Please add that.
Is the request really about definition queries or about conditional formatting in an attribute table? i.e. If <some condition> then format a cell a certain way? If so, I think that is captured in this idea https://community.esri.com/t5/arcgis-pro-ideas/conditional-formatting-in-attribute-table/idi-p/92989... Please review and provide clarifying details.
Thank you
KoryKramer
Hi @RobertBorchert I wanted to check in with you again to see if you can provide any details per my above comment. Please let us know. Thanks!
KoryKramer
Status changed to: Closed
Closing this pending clarification. We can reassess the idea once we have answers to the questions asked. Thank you!
