Switch between label classes within label properties pane
1356
07-17-2024 03:50 PM
Status: Already Offered
wayfaringrob
Honored Contributor
It would be great to be able to switch between label classes at the top of this pane. Right now it requires some extra clicks, either the labeling tab on the ribbon and then the drop down there, or, if you happen to be in Map View (which I am not most of the time when I'm working on labels), you can use the list by labeling (would be great to have this in Layout: Access list-by-labeling TOC from layout view - Esri Community ).
The way labeling properties are controlled in Pro continues to baffle me, with controls strewn about in so many different places. This would help reduce the back and forth a little.
3 Comments
AlfredBaldenweck
You should be able to switch between label classes by clicking where it says "Class" in the Labeling Pane.
WendyHarrison
You can switch between the label classes for a layer under the Class arrow - see below
when you select another layer in the Contents pane those label classes will become available on the Label Class pane
KoryKramer
@wayfaringrob since this idea requests the ability to switch between label classes from the pane, and it has been pointed out that is already possible, I'm setting this to Already Offered.
Please let us know if we're missing something about the request and we'll need to clarify the title and description or submit a more specific idea.
Thank you
