Sounds to me a biased answer. It limits the posibilities
Today, at the end of 2018, with the ArcGIS pro SDK in version 2.2, and I am not able to generate unit tests, not even mention apply TDD, because the SDK does not have Interfaces and most of the classes are sealed.
Having interfaces would make testing so much easier. The class library is great, just lacks the interfaces which is the base for being able to write independend unittests. Currently it is hard to convince people to write unittests, with so many obstacles on the path.
