Hi @HectorValleRuiz ! As per the documentation: "Symbolizing clusters requires a summary statistic field. A summary statistic field is created when clustering is first turned on and is listed as the summary field in the Symbology pane. To create other summary statistics and use them with your cluster's symbology, see Calculate summary statistics for aggregated features ."
Have you tried creating a new summary statistics field for use in symbolization? If you've tried this and you're not able to use it to symbolize clusters, it might be more appropiate to contact technical support.
I'll be marking this as Needs Clarification for now. Thanks!
Hello @ValeriaChavez
I have created summary statistics fields that allow indeed to symbolize clusters with "Unique Values", but this only works when the summary statistic field is based on the "Mode" statistic type.
My suggestion is to allow the same kind of symbolization when using any other statistic type (sum, mean, min, max and standard deviation). Currently ArcGIS Pro shows the following message when there isn't any "Mode" summary statistic field:
'Layer does not contain a sufficient summary field for categorizing unique values. Open the Summary Statistics dialog and create a summary field using the "Mode" statistic type'.
I already contacted technical support and they confirmed that this option does not exist yet, which is why I posted it here 🙂
I hope this clarifies it.
it would very helpful if you could provide some workflows/use cases where you need to symbolize aggregated features with unique value renderer using other types of summary stats (such as sum, min, avg etc.) .
Hi @HectorValleRuiz! I will be closing this Idea for the time being. If you're able to share workflows/use cases where you need to symbolize aggregated features with unique value renderer using other types of summary stats (such as sum, min, avg etc.), we can re-open it. Thank you for being an active member of Esri Community.
Hi @ValeriaChavez ,
To clarify, I am able to cluster a point layer like this in AGOL but I don't see an option to in ArcGIS Pro.
See this thread --> Chart Clustering Aggregation Option in ArcGIS Pro - Esri Community
