Speed up jupyter notebooks in ArcGIS Pro
564
01-13-2026 04:28 AM
Status: Closed
CordulaGöke
I appreciate the integration of Jupyter Notebooks into ArcGIS Pro, as it greatly enhances workflows. However, the performance is significantly slower compared to other platforms such as VS Code. Tasks like opening notebooks and modifying the environments have been consistently slow for a long time. Since upgrading to ArcGIS Pro 3.6.1, execution speed has also degraded to the point that it renders it useless.
If other applications can handle Jupyter Notebooks efficiently, ArcGIS Pro should be able to achieve similar performance. Improving speed and responsiveness would greatly enhance the user experience and productivity for data science and GIS workflows. For the time being I will experiment with the advice of how to work with aprx from outside ArcGIS pro.
3 Comments
ValeriaChavez
Status changed to: Closed
Hi @CordulaGöke!
As we note in the ArcGIS Ideas Submission Guidelines, performance issues are not a good fit for Idea Exchanges. Just like with bugs, performance issues should always be reported to Technical Support for further investigation.
 Thank you for being an active member of Esri Community!
CordulaGöke
@ValeriaChavezContacting technical support seldom leads to anything. With our setup our first technical support contact is the local distributor. Especially the case that opening them is slow, what are they supposed to do about it?  It is not that they are not working, so I don't think it qualifies as a bug and the other option to workaround it is just not have notebooks in the project.
