Specify version when creating an FGDB using the File Geodatabase API
1377
03-03-2011 11:50 AM
Status: Closed
by Anonymous User
Not applicable
The new File Geodatabase API provides a CreateGeodatabase method. Since the API only supports 10.0 databases at this point, there is no immediate need to specify a FGDB version. However, when ArcGIS 10.1 is released, it will be useful to specify which version of file geodatabase is to be created.
I propose an overloaded CreateDatabase method that would take a parameter that specifies the geodatabase version to create (10.0, 10.1,...).
2 Comments
BillMajor
Including 9.2 and 9.3 versions.
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to open, duplicate Idea
