I would like to see the ability to sort a string that has numbers at the beginning as a Number.
i.e. I have addresses 1 Main Street, 10 Main Street, 2 Main Street. It is going to sort them in that order.
Until such time that this happens... You can do it with a field calculator expression in the interim if you are in a pinch
Create them correctly in the first place
def nat_pad(val, pad='0000'):
"""natural sort... put the import re outside of the function
:if using the field calculator
: calculator expression- nat_pad(!data_field!, pad='a bunch of 0s')
import re
txt = re.split('([0-9]+)', val)
l_val = len(str(val))
txt_out = "{}{}{}".format(txt[0], pad[:-l_val], txt[1])
return txt_out
a = ['a1', 'a20', 'a2', 'a10']
print("input - \n{}".format(a))
vals = [nat_pad(i) for i in a]
print("output - \n{}".format(vals))
input -
output -
['a001', 'a020', 'a002', 'a010']Then sort
b = ['a001', 'a020', 'a002', 'a010']
b.sort()
b
['a001', 'a002', 'a010', 'a020']Sort them if they aren't
def natsort(text_lst):
"""natural sort returns text containing numbers sorted considering the
: number in the sequence.
:originals used lambda expressions
: convert = lambda text: int(text) if text.isdigit() else text
: a_key = lambda key: [convert(c) for c in re.split('([0-9]+)', key)]
import re
def convert(text):
return int(text) if text.isdigit() else text
def a_key(key):
return [convert(c) for c in re.split('([0-9]+)', key)]
return sorted(text_lst, key=a_key)
vals = natsort(a)
print("natural sort - \n{}".format(vals))
natural sort -
['a1', 'a2', 'a10', 'a20']
