Sort joined fields
2338
06-06-2023 07:25 AM
Status: Open
Bud
Legendary Contributor
ArcGIS Pro 3.1.2; mobile geodatabase
I have a FC joined to a standalone table. I want to sort one of the joined fields.
In the attribute table, if I right-click a joined field, the sort ascending and descending options are greyed out.
Could ArcGIS Pro be enhanced so that we can sort joined fields?
It looks like this is an ArcMap equivalency issue — it's possible to sort joined fields in a Oracle 18c 10.7.1 EGDB (mobile GDBs aren't supported in ArcMap).
5 Comments
Bud
Esri Case #03359247 - ArcGIS Pro 3.1.2 - Unable to sort joined fields
BUG-000159170 - ArcGIS Pro 3.1.2 - Unable to sort joined fields when a mobile geodatabase standalone table is joined to a mobile geodatabase feature class in a 1 to many join.
Kevin_MacLeod
Still a bug, over a year later. What's weirder is I see Select by Attributes is selecting WRONG on joined fields. I have an Inspection Date. It's selecting stuff BEFORE a date where I have a Greater Than condition.  Joins in Pro have issues.  And attachments don't come through from joined fields in webmaps.  For example if we want pictures in webmap popups from a related table that was joined to its point layer, for inspections of hydrants for example.  These basics would be more helpful for more customers than Digital Twin/VR/GeoAI.  And less development effort.
Kevin_MacLeod
Still a bug.  Yes it's one to many. Anyone? Bueller?
I can sort and manually select so to do what I do it's fine but the issue with Def Query is a bigger deal. Selection is temporary for GISers. Def Query can be needed for services; since unlike Selection; it stays updated as data changes; and this bug means joined date fields.... don't work with Def Query. Kind of a big thing.  Since GIS often has inspection or fieldwork data, and of course Date of work is almost always a field.
KeithAddison1
Still having this problem in 3.6.2.  Error says The SQL statement was not a select statement[STATE_ID = 0]
Thankfully I can do what I need in Excel.
