Snapping option is deactivated while using streaming
943
03-05-2025 03:10 AM
Status: Implemented
RutEikeland
Snapping option is deactivated while using streaming (something that ESRI chose to do). The solution is to hold the spacebar, which is NOT a good solution when the user has to hold it 6 or 7 hours a day, and it can lead to muscular problems. Can ESRI change this and fix it so it become similar to Arcmap, where the snapping is also activated while streaming.
Tags (1)
2 Comments
JenniferCadkin
JenniferCadkin
An option to honor Snapping Settings while Streaming is implemented at ArcGIS Pro 3.6.
https://pro.arcgis.com/en/pro-app/latest/help/editing/create-segments-by-streaming-vertices.htm#ESRI...
