Show nodes, pseudonodes and dangles while editing
5654
9
06-02-2021 04:40 AM
Status: Implemented
StåleHaug
Basically: symbolize nodes, pseudonodes and dangles within a featureclass while editing. Same as the Node Renderer available for ArcMap in the Production Mapping extension.
9 Comments
RolandDuhaime
Yes, this is needed in ArcGIS Pro and essential for rapidly creating clean data.
RenRosin
I've been searching for a tool in Pro that will do this, is there nothing like it?
Nicolas_GREHANT_IGNFI
This ArcMap/Production Mapping "Node Renderer" tool is hugely used by the Colombian Mapping Agency. Sure that it must be added as the IGAC is moving today to ArcGIS PRO!
ChrisJacob
I used to use the equivalent of this all the time when editing coverages in ArcEdit.  (Yes, I'm old!)
It would be highly beneficial to have an equivalent display / symbolisation option in Arc Pro.
Heather_Campbell
Having this functionality in Pro would be very helpful. When symbolizing a line feature for instance, users could go to Symbology > Properties > Layers > Shape marker > Marker Placement > Placement (drop-down menu). There are currently drop-down menu options to place markers at extremities, on vertices, and others. In my opinion, it makes sense to have an option to also place markers at dangles.
JenniferCadkin
Scott_Harris
JenniferCadkin
StåleHaug
We have already started using it, and it is just what we wanted (and maybe even more). Works perfectly so far, so thanks  for implementing it.
