Show keyboard shortcut on tooltip
2570
05-24-2023 09:37 AM
Status: Implemented
wayfaringrob
Honored Contributor
It would be really helpful for learning and efficiency if command tooltips all displayed the associated keyboard shortcut if one is available. There are a few that do this already (ex. undo), but it seems like most don't. Obviously there's a list of these online but having them right there would be really useful and save lots of time, not only in searching for the shortcut, but using it subsequently.
5 Comments
SimonSchütte_ct
"Obviously there's a list of these online"
Just adding the link to the mentioned list here: ArcGIS Pro keyboard shortcuts—ArcGIS Pro | Documentation
wayfaringrob
@SimonSchütte_ct  ope, yes perhaps not so obvious, thanks! I just anticipated someone linking it and marking the request as resolved...
KoryKramer
@wayfaringrob have you tried in ArcGIS Pro 3.2 yet? Most commands with a shortcut assigned will display the shortcut in the screentip. If a command doesn't have a shortcut assigned, once you assign one, it will display in the screentip.
See this blog - I hope this helps!
https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/contextual-keyboard-shortcuts-in-arcgis...
wayfaringrob
@KoryKramer  not yet. I might get it early next year. Thanks for the tip.
KoryKramer
