Setting default units should be immediately reflected in measure tool
1492
08-16-2024 09:03 AM
Status: Open
Bud
Legendary Contributor
ArcGIS Pro 3.3.1
I've set the default units in the Options to distance=feet and area=acres:
But when I open the measure tool in the map, the measure tool units are still in metres.
I think it would be more intuitive if the unit changes I made were immediately reflected in the measure tool if the tool is not already open.
4 Comments
Bud
adunckel_nrcs
Would be a super helpful improvement to have defaults set. As well as for the mode.
MackenzeOriger
To add to this, it would be helpful to set a default for the mode (Geodesic, Planar, etc.). I often have to measure in Geodesic, but every time I change to a different tool and then go back to the measure tool, it reverts to Planar.
Debert
@Bud @MackenzeOriger @adunckel_nrcs I have a recent enhancement logged for this exact issue- currently with 29 kudos. You can add your use cases here.
The more traction this enhancement gets- the more likely it is to be reviewed by Esri and implemented in the future. Cheers!
