Set the lowest range in the color ramp for Symbology
780
02-06-2015 01:20 PM
Status: Open
CarmenBremmer
When importing symbology from another layer, there are times where the new data has values that fall below the old data causing it not to draw.  It would be nice to have the lowest range default to 0 - max instaed of having it set to a value that can't be changed without losing all of the other break values
1 Comment
RyanPaquette1
In ArcGIS Pro the Import Symbology function will rebuild your classes based on your target dataset, so it looks like the functionality you are looking for is the default in ArcGIS Pro .
