Set maximum zoom for ArcGIS Pro
2787
05-15-2018 10:34 AM
Status: Open
emmornile1
I find that the mouse roll zoom can be very sensitive and I often accidentally zoom to a scale that is appropriate for solar system mapping, the layers are then rendered slowly and the map is not usable.  The solution is to hit the zoom to previous extent.  The option would prevent users from accidentally zooming to an unusable extent.
Mock up of Map Properties Extent
2 Comments
KoryKramer
It seems like if we had Only Display These Scales - in ArcGIS Pro‌ it would resolve the problem because you'd be able to set scales that are appropriate for your work and then only display those when zooming...
emmornile1
Yes that sounds like it would work.
