Set Default Select Tool in ArcGIS Pro
5899
19
01-03-2025 07:17 AM
Status: Implemented
RobertAnderson3
MVP Regular Contributor
The select tool defaults to the rectangle select, I almost always would prefer the Lasso tool. There should be an option to set your default choice of selection in your projects.
Tags (1)
19 Comments
Michele
Yes!!
ChristineSalvadore
@NathanShephard That's an ideal scenario for me
NathanShephard
Thanks both!  Will see what we can do.  🙂
RobertAnderson3
Hi @NathanShephard yes having Pro remember which select tool I was using last would also be effective. It would basically do the same thing for me as if there was a setting because I find I almost exclusively use the lasso Select.
Thank you for taking a look at this and seeing what you can do!
Michele
Thanks @NathanShephard.  Appreciate you looking into this.  So many people I work with complain about it. 🙂
NathanShephard
Working on this for Pro 3.6 (as per discussed above -- "remember the last mode of the Select tool").
Thanks again for the input and discussion!
-Nathan.
NathanShephard
Included in ArcGIS Pro 3.6!
The last active Select tool is now remembered and honored when closing/re-opening Pro.
Thanks all - really appreciate the discussion and openness to a creative solution.
Hope this helps!
-Nathan.
Michele
Thanks Nathan!! Looking forward to this feature in 3.6!!
ChristineSalvadore
Thank you!
