Select By Attributes — Use recent selection expressions from a picklist
81
Tuesday
Status: Open
Bud
Esteemed Contributor
ArcGIS Pro 2.9.5
Edited.
I't would be helpful to see a list of recent selections I made as a drop-down in the Select By Attributes window. I'd be able to choose a past selection expression and load it/run it.
I'm aware that I can manually save and load SQL expression files. As well as save and load definition queries. But that's different than an easy-to-use, automatically-generated list of past expressions from the current Pro session.
2 Comments
ZachBodenner
Definitely a good idea, it would be great to see that co-located with the attribute selection tools.
As of (at least 3.2 but maybe earlier?) the geoprocessing history does capture select by attributes, though I believe you need to do it from the ribbon as opposed to the attribute table, but I may be wrong about that.
It isn't exactly what you're looking for, but you can pop those open and copy-paste the SQL query.
Bud
Thanks @ZachBodenner.
