Save Overwrite Options with History
273
09-04-2025 12:24 PM
Status: Open
ChelseaRozek
MVP Regular Contributor
As of Pro 3.5.3, when I ran a geoprocessing tool (Spatial Join) with a particular Overwrite Option (Replace Existing Records) and then tried to run it again from the History, it went back to the default Overwrite Option. It would be helpful if it would save what you had chosen for that particular run. I don't want to permanently change the default, I just want to be able to run this exact step in my workflow again from the History or History Favorites without having to remember to change the choice at the bottom every time. If I forget and it defaults back to "Delete existing", it removes the layer from my project and throws out the definition query I had on it. It doesn't seem very user-friendly if History isn't remembering how you ran the tool.
2 Comments
BBicking1
Hello Chelsea,
just as fyi...
just a month before you logged yours here I had logged a related issue in our repo.  Your idea is now linked.
ChelseaRozek
@BBicking1 Great, thanks!
