Restore Field-Based Label Rotation
1255
10-09-2025 06:43 AM
Status: Already Offered
MarcelSt-Germain
Summary of the Problem
In ArcMap, it was possible to rotate labels dynamically using a numeric field (e.g., ) via the “Rotation” setting in the label properties. This allowed precise control over label orientation for nautical charts, engineering diagrams, and other use cases requiring per-feature rotation.
In ArcGIS Pro, this functionality is no longer available. The Label Class interface only offers orientation options relative to geometry or graticules (e.g., horizontal, parallel, perpendicular), but does not allow rotation based on a user-defined field. The tag is also ignored in dynamic labeling, and the “Rotation” option is absent from the Labeling ribbon and class properties.
This limitation breaks workflows that rely on precise angular control, especially in professional cartography and automation contexts.
🙏 Feature Request
Please reintroduce the ability to rotate labels based on a numeric field, as was available in ArcMap. Ideally, this would appear in the Label Class > Position tab as a “Rotation from field” option, allowing users to select a numeric attribute (e.g., ORIENT) to drive label rotation.
This would restore a critical capability for advanced labeling workflows and support migration from ArcMap to ArcGIS Pro without loss of functionality.
4 Comments
WendyHarrison
@MarcelSt-Germain
You can find the Rotation field option under the Rotation expander.  It is available for point features - the same as in ArcMap
WendyHarrison
MarcelSt-Germain
@WendyHarrison
Hi, I know that.  Can't understand why, but in my case it was unaccessible when making my suggestion.  After some other works, I retry and then it was accessible ?????
Bafut, the main problem persists.  The rotation doesn't work as expected.  In arcmap, if the pictogram was N-S so 0 degree, and a rotation of 45 degrees is applied, the picto move 45 degrees and the label fallow it at the same angle.  Now, the label doesn't fallow the picto.like in arcmap (same pictogram).  The label is with a strange angle.  To be able to leave the label in the same angle, I had to put an additional angle of 120 degrees.  The problem, with this additional angle, the label doesn't fallow anymore the positon setting.  Right or left of the pinto is translated in below.  Again, in arcmap with maplex it's working as expected.  Verry frustrating.
WendyHarrison
@MarcelSt-Germain
I'm seeing the same results from ArcMap to Pro.  Can you provide screenshots of what you're seeing?
