Remove web map from project's Catalog - change text from 'delete' to 'remove'
7282
8
03-29-2021 09:55 AM
Status: Closed
Andy_CS
If I want to remove a database (db) connection from my project I locate the db in Catalog, right-click on it then choose 'remove'. This makes sense, the db is removed from my project and does not get deleted
If I want to remove a linked web map from my project I locate the web map in Catalog, right-click on it then choose 'delete'.The map is removed from my project and does not get deleted from portal. If I locate the same map in portal right-click on it and select 'delete' it will delete the item.
If i choose delete for a normal project map in Catalog it will be deleted - as expected.
I think the language (including the tool-tip) used when removing a web map from a project's Catalog should be changed from delete to remove.
8 Comments
AletaVienneau
Delete is the correct word. What the project has is a Pro map that was created by converting the web map to a Pro map. The Pro map is independent of the original portal item.
If your workflow involves using the web map as-is is, I can see how you might think of Delete as if it were just a Remove. However, it is not a requirement to operate this way. You can change symbology, add and remove layers, etc. from the Pro map without having any effect on the web map. That is, a linked map is a normal project map.
When you delete the Pro map you are deleting the Pro map. It is a Delete operation because once it is deleted and the project is saved you can't get the map back again. Yes, you can start over by importing the web map, then repeating your process of changing symbology, adding and removing layers, etc. But, in the meantime you have lost your changes, and if the web map was modified since you first added it to your project there might be something it had before that you can't get back.
The Pro map is linked back to the original web map for purposes of providing notifications if the web map is updated, and keeping your local copy up to date if this is what you want to do. You are allowed to choose when to accept any updates so you can save a copy of any customizations you made before replacing your local copy of the web map. See Add a web map or web scene from a portal
The linked Pro map is not intended to be used as a proxy for managing the portal item. If the Pro map is deleted, it is expected that you are deleting your local copy of the web map and the portal item remains unaffected.
Andy_CS
Thanks for the explanation, makes complete sense - I can see why it is Delete now.
I have been thinking of the linked map as the web map in portal not a Pro map.
AletaVienneau
Status changed to: Closed
Changing this idea's status to Closed, since the behavior is expected and the software is working as designed.
HollyTorpey_LSA
Hi @AletaVienneau,
I realize this idea is long closed, but I agree with @Andy_CS that this wording is confusing. I had the same trepidation about deleting a linked map from Pro because for many other items in the Catalog pane (folders, geodatabases, toolboxes), Delete nukes the original while Remove removes it from the project but leaves the original alone. I was 95% sure deleting it wouldn't delete the original from AGOL, but that 5% kept me from clicking Delete and instead sent me to Google, which is how I got here. I now am 100% clear that the map is only a linked local copy and that delete does accurately describe the action I want to take, but Pro doesn't make it obvious that it's only a local copy (adding that to the tooltip would help). It's also not super easy to find documentation of what happens when a linked local copy of a web map is deleted. For that reason, I still think the contextual menu item should be updated to say "Delete local copy" when the selected map is a linked local copy of a web map. Alternatively, the confirmation dialog could be updated to say "Are you sure you want to permanently delete the local copy of ..."
Thanks!
LindseyGreidanus
Just want to add my +1 to this idea, it is very alarming that it says delete and not remove. I think better terminology like "Delete local copy" would be a good idea.
TiffanyStram
I'll also add my +1 to Holly's & Lindsey's posts above.  I've been afraid to "delete" a linked map from my project for a very long time because of the terminology!
Meredith_Keraga
Another +1 from me! It would be really helpful and less scary to have terminology that indicates you are deleting the map from the project, not deleting the original source data/map. I agree with Holly's comment that this is confusing when compared with other uses of Delete vs Remove in the catalog.
curbanoiwcz
@AletaVienneau, I had the same experience as Holly. Can you please reopen and have esri reconsider the wording in the message? Googled and ended up here. Thanks!
