Remove guide with a swipe
1370
03-22-2024 09:15 AM
Status: Open
RoseF
We use guides in our layouts with some frequency. Often, when I'm laying a map out, I'll create a lot of guides quickly and adjust them relative to each other. In ArcMap, I could quickly remove a guide by clicking it and "dragging" it off of the ruler with a quick swipe of my mouse. This does not seem to be a functionality in Pro; instead, you have to right click and choose "remove guide".
Similarly, to add a guide, in ArcMap, it was as simple as clicking the ruler where you wanted to add a guide. In Pro, it seems like the only way to add one guide is to right click the layer and choose "add guide". I understand that you can add multiple guides but for my workflow, it's nice to quickly click on the ruler to add a guide, move the guides around, and quickly remove them by just swiping them off the ruler.
Any chance this could be implemented in Pro?
1 Comment
kkefer
To add multiple guides at the same time (which you can then manually adjust where needed), when right clicking to add guide - select "Add Guides". Select which orientation you want, and how you want them placed (I personally like evenly spaced) and it will drop a bunch.
Likewise, when you want them all gone - you can right click on one and then choose "Remove All Guides" and they all disappear.
I hope this helps in the interim.
