remember querys
3028
7
06-13-2014 02:20 PM
Status: Open
JordynMitchell
make a 'query rememberator' so querys can be remembered/stored and re-used
(not just saved out to a file)
this would apply to sql queries, definition queries, label classes, cal files - etc...
maybe point to a folder where they are stored as individual .txt/.cal files with titles to help select them from a drop down pick list (and ability to edit the pick list)
7 Comments
KoryKramer
For the part about the pick list of queries to choose from, you may want to join the discussion at https://community.esri.com/ideas/2358‌.  It could be an interesting design consideration.
KoryKramer
Since this idea was posted, ArcGIS Pro has implemented the ability to define multiple definition queries on a layer, name them, and switch the active query using a drop-down list that shows the query names.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/definition-query.htm
I realize that definition queries is just one of "sql queries, definition queries, label classes, cal files - etc..." but wanted to make note of it as possible.
Bud
Merged from a separate idea.
Select By Attributes
It would be helpful to see a list of recent selections I made as a drop-down in the Select By Attributes window. I'd be able to choose a past selection expression and load it/run it.
I'm aware that I can manually save and load SQL expression files. As well as save and load definition queries. But that's different from an easy-to-use, automatically-generated list of past expressions from the current Pro session.
ZachBodenner
Definitely a good idea, it would be great to see that co-located with the attribute selection tools.
As of (at least 3.2 but maybe earlier?) the geoprocessing history does capture select by attributes, though I believe you need to do it from the ribbon as opposed to the attribute table, but I may be wrong about that.
It isn't exactly what you're looking for, but you can pop those open and copy-paste the SQL query.
Bud
Thanks @ZachBodenner.
KoryKramer
Bud
@KoryKramer Yes, looks like mine is a duplicate.
