Reconcile Conflict Dialog Box Expanded Functionality
734
01-05-2012 01:32 PM
Status: Closed
EricGordon
Conflict Dialog Box should be
1. merged with Version Changes Box (eg. not limited to reconcile),
2. allow functionality even if only changes to one version has occured, not requiring changes in both the edit version and target versions.
4 Comments
KarlWilson
It would be great to be able to review non-conflict changes and accept/reject/amend them as required.
The current Version Changes tool is very limited in its functionality. It will show you all the changes, but not let you actually do anything. The Version Differences tool in the Data Reviewer extension is slightly better, as it allows you to browse through the differences and make amendments directly to the affected features in the main map view. However if an individual feature has been incorrectly deleted, there's no way of resurrecting it.
There is some discussion on the topic in the forums:
http://forums.arcgis.com/threads/58966-Version-and-editing-management
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. You can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to duplicate Data Management Idea
