Python packages Manager offline
3309
7
06-16-2022 09:36 PM
Status: Closed
OmerZilkha
For those who work on an offline environment adding new python packages is very hard because of dependencies.
The soultion — have a program/website that simulates the python packages manager without having to install pro. You could download whatever packages you want and know that you could later use them in an offline arcpro environment and they would work
7 Comments
DavidSolari
Conda supports this already, open the "Python Command Prompt" from your start menu and use this command:
conda install "\path\to\my\downloaded\package.tar.bz2"
I guess an "install package from path" button would be a nice feature for Pro to supplement this.
OmerZilkha
The issue arises when one has the PRO installed on the offline environment
and no PRO on the online environment. One could download the python
packages on the online environment but could not know if he would have
conflicts and dependency issues when he imports the packages to the PRO on
by Anonymous User
I haven't done this with a Pro environment, but I've had success using conda pack to build offline environments.
Perhaps you could clone your Pro environment (offline) and use a YAML file or other to rebuild everything on an online machine. Then install the packages you need, and conda pack back to the offline machine.
It's not pretty, but I'd be very curious to see the results.
HannesZiegler
You're in luck, this is already in the product plan and being worked on,  please see https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDExODQzMA==
Just to clarify, this won't be an offline package manager - just a simpler way to get the arcgispro-py3 dependencies in an offline environment. An offline package manager is not in the product plan and it is unlikely it ever will be, as other users have noted there are ways around this.
HannesZiegler
We are at this time still assessing possible solution(s) for this issue.
HannesZiegler
We're working on this!  This status does not guarantee that the functionality will be in the next release, but development work has begun. Release cycles vary by product so make sure to check the product life cycle information to get an idea of when to expect the next release.
Please note that what we are working on is a way to clone the default environment arcgispro-py3 offline (without requiring an internet connection), not an offline package manager.
HannesZiegler
Status changed to: Closed
Our work in this area focuses on supporting cloning on disconnected computers, enabling offline creation of Python environments - but not package management in an offline environment. At ArcGIS Pro 3.7, cloning Python environments is faster and supports cloning on disconnected computers, enabling offline creation of Python environments.
We are not planning to provide an offline package manager or a separate program/website that simulates the Python Package Manager experience outside of ArcGIS Pro.
Thank you for your understanding,
the Python team
