Imagine someone needs all of your maps NOW! I can blast my entire project to a thumb drive, or I could:
Where each mapx file would simply be named the same as the map.....
I am often making a small change to many layouts or maps at a time, then having to share each one, one by one to its production environment. For example, the print templates we use in our custom print service, folks are always finding some error and I have to update and re-share all the layouts again. I feel like I should be able to highlight 2 or more layouts and share them all at once, and the file name would just be the name of the layout, which is usually the case.
Would be nice if there was a Share>Map File (.mapx) option under the right click menu for Maps in the Catalog pane so we don't have to open them completely to get the toolbar to display it as an option.ChelseaRozek_0-1736260876537.png
Like how when you right click feature classes in the Catalog Pane, there's an Export option. You don't have to add them to a map to then be able to export them.
I was just thinking about this. It'd be very nice.
