It would be a huge time saver if we could evaluate tables in PRO with the tools used in Excel or Access to check for cardinality. On the columns there should be a drop down for a quick filter for a selection of attributes, or 'quick view' of the unique values in that column.
Even just the summarize tools are missing from Desktop. If there was a way to get stats off the columns, this would make Pro a GREAT resource.
@pro #pro #table cardinality viewtable join and relates
Statistics is in Pro 2.1.
Other than that, you're looking for a quick way to see unique values in a field, correct?
I know this idea was posted a few years ago, but it's something that I think anyone who needs to spend a lot of time and effort with attribute tables would appreciate. I would describe this a functionality like an Microsoft Access table, or an Excel table with filters. In the header, you can set a filter using either a list (for smaller tables) or a text filter. The example below is a table in an enterprise geodatabase, but it is so much easier to use in Access (viewing only).
(merged from a duplicate idea)
In SQL clients like SQL Developer and Toad, we can filter on a column like this:
It would be handy if we could do something similar in the Attribute Table in Pro.
It wouldn't need to be a new/separate filtering mechanism. It could simply be a way of generating the Select by Attributes expression.
It is an extremely useful tool for ArcGIS Pro table!
