ObjectID for Map Series Name
1800
02-27-2022 09:04 AM
Status: Under Consideration
BrettFrahm
When using a Spatial Map Series on a dataset it would be very useful to be able to just use the ObjectID as the "Name Field" and "Sort Field" parameters. Not all map series layouts are going to be on specifically named features. In my use-case I just want to make a layout for every single feature in a dataset and the easiest way to do that is to use ObjectID. ObjectID also acts as the best way to determine what layout is for which feature because it is a unique identifier.
I realize that one way to do this would to to transfer the values to a integer field, but I'd much rather use ObjectID as I am using Production enterprise feature classes that are seen by our entire organization and I don't want this field to be visible and I don't want to maintain it.
As an expansion on my use-case I've thought about using Arcpy.MP to keep an up to date map series layout for every feature and with ObjectID I'd be able to instantly tell which features have not had a layout yet.
2 Comments
arthurV
This is one of the many exemple I have no idea how it is possible this is not a basic feature of ArcGIS Pro.
As numerous time, Esri just feel like they do not care about users.
Why could you use globalId or objectid with the select by feature fonction, but nos as the index parameter of a Map Serie?
AubriOtis
