measureOnLine() function in Arcade
468
03-02-2022 08:41 PM
Status: Open
Bud
Legendary Contributor
Could Esri consider adding a measureOnLine() function to Arcade?
Returns a measure from the start point of the line to the in_point.
measureOnLine (in_point, {use_percentage})
ParameterExplanationData Type
in_point
A point that is used to measure from the start point of the polyline.
Point
use_percentage
If False, the measure will be returned as a distance; if True, the measure will be returned as a percentage.
(The default value is False)
Boolean
Return Value
Data TypeExplanation
Double
A distance or percentage.
That would be helpful for linear referencing purposes.
