Maplex Label Sinuosity
688
05-11-2026 03:36 PM
Status: Open
MErikReedAugusta
MVP Regular Contributor
The vast majority of the maps I make have turnaround times that mean almost all of the labeling I do has to be fully automated, using Maplex.  Any solution that requires me to manually create a label as a text item or convert a set of labels to graphics/etc. increases my turnaround too much for the constraints I have to meet.
For most things, Maplex is sufficient for "good enough" labels in the projects I have, but it really seems to struggle with high-sinuosity feature classes, even at zoom levels where that sinuosity is functionally irrelevant.
Case A (Maplex "Centered curved", ArcGIS Pro 3.1.3):
Note the areas indicated by red arrows.  Maplex results in excess kerning between the "S" and "p" of "Spirit", while the "i" and "r" of the same word, and the "[" and "L" later in the label crash together in an unsightly mess.  All three of those locations are cases where there's a sharper cut in the geometry of the stream centerline that the label is trying to follow.  As a sidenote, the centerline geometry in question is made up exclusively of straight subsegments; there are no true/bezier curves.
As an alternative, I could select "Centered straight" for my labels, but that takes the issue too far towards the opposite end of the spectrum and often looks incredibly odd for riverine features.
Case B (Manual):
This label was made with a text element added in the Layout view, and has only 3 vertices to control the bezier curves, and we can see that the kerning between individual characters is quite a bit better.
Related Perspective/Use Case 1:
In addition to using labels as finished products in an output map, I also use them as sort of a heads-up-display of selected information about a feature, when I'm doing more complex editing of data.  In these cases, I never even create a Layout; everything is done in Map View.  In addition, the extra labor to create manual labels would negate the efficiencies created by that HUD approach to data review/intake.
Related Perspective/Use Case 2:
When producing a Map Series with a large volume of individual maps, manual creation or editing of labels is an unrealistic burden, and yet any increased variation in scale between the maps increases the likelihood of kerning errors and an inferior map product.
Suggested Improvement:
Add a "maximum sinuosity" parameter to the Centered curved and Offset curved label placements.  Features with greater sinuosity than the indicated value would essentially round the sinuosity down to that maximum on-the-fly, for the purposes of determining label placement.
Alternately, the parameter could reference average sinuosity over the portion of the feature covered by the label.  This would cause a feature with many rapid curves to be averaged out to a central throughline, like finding a "best fit" line on a statistical line graph.
3 Comments
JesseWickizer
The Maplex River placement style is designed for this situation or for any features that have many tight curves like this. River placement style generalizes the turns of a river and places the label following that smoother line.
Here are some examples that show how river placement can place labels on much smoother curves than using the regular placement style.
MErikReedAugusta
@JesseWickizer
That's definitely a good point, and I should have noted that the screenshots I included were using the River placement setting.  With regular placement I can confirm the issues were even worse, so the River placement is definitely helping a little.
But I feel my screenshots show that the River placement (at least as far as 3.1.3) doesn't quite go far enough in generalizing the geometry.  I work exclusively at county-level scales and closer, so riverine geometry gets quite over-complex quite quickly, from a label perspective, but that complexity is often important outside of labeling, and can't easily be thrown away.
BrennanSmith1
For a workaround in the meantime, you could probably create a secondary stream layer using Simplify Line and apply the labeling to that layer instead.
