Charts available in pop-ups are great, however x & y axis are not configurable. By default the x axis is derived from the Field Name as opposed to the Alias, and its direction cannot be edited, which means in the best case scenario, you'll see the first 2 letter of Field name.
For example with following Field Name:
The chart legend will be AU..AU..AU..AU..AU.. instead of allowing you to change scale and orientation of axis to display:
...which makes the chart understandable for everybody.
Same applies for all types of charts: Column, Line, Pie and Bar charts.
All my work is in a GDB.
This is exactly the dilemma I am having right now as well.
I need the bottom labels in my Pop-Up chart to read Total Population, Enrolled on Reservation, AIAN Alone, AIAN Alone OR in combo with 2 or more races....etc. instead of "CDAR":
Configuring charts in Tableau seems almost easy a Cave Man could do it, wish the same could be said for ArcGIS Pro. It would also add a lot more power to ArcGIS Dashboards.
