Make map grids and graticules scale dependent
3384
09-06-2010 04:18 PM
Status: Implemented
MichaelKraus
Measured grids to be displayed on the map layout are set with a fixed interval, which may not be appropriate at all scales.  For example, users may want a 100m spaced grid when printing out large scale maps, but a 10km spaced grid when printing out small scale maps.
In a similar way to setting the scale range of a layer in ArcMap, the measured grids and graticules should be able to be automatically shown / not shown based on the scale of the map.  This way a series of graticules could be created to suit all scales the map will be used at.
5 Comments
GraemeBrowning
This idea seems to be related to the one that I would most like to see implemented ...
Reference grids/graticules should be accessible to ArcPy.Mapping
TheodoreF
Good simple idea!
AubriOtis
AubriOtis
AubriOtis
In ArcGIS Pro 3.3 grids and graticules have a visibility range you can set. The grid will only be visible if the map frame is within that scale range.
