Leader lines should have anchor points at horizontal centre of top and bottom of text bounding box
7476
13
04-09-2013 09:17 PM
Status: Closed
wilfredwaters
In the attached image you can see that leader lines have 2 possible anchor points, the vertical centre of the left and right of the text bounding box. Unfortunately, it is not possible for the anchor point to be the horizontal centre of the top or bottom of the bounding box.
Try it yourself by dragging the end of a leader line in a circle around the text it will snap between the left and right only.
This makes for awkwardly placed leader lines in cramped conditions.
0EME0000000Tbej
For example, if the text is directly above the item to which the leader line is pointing, it will have to go at an angle down from the vertical centre of the text across to a point below the horizontal centre, see next image.
0EME0000000Tbeo
In the above image you can see the results of my suggestion (a line I have had to draw in using the Draw toolbar) where the line has an anchor point at the horizontal centre of the top of the text bounding box.
Can ESRI add one at the top and the bottom to accompany the ones on the left and right?
Microsoft Word and Excel have something like this functionality when you insert a shape:
0EME0000000Tbet
Their leader line version, however, is a line where you can adjust the position of the anchor and the destination point. This might be optimal for ArcMap too.
Wil
13 Comments
mzhang
I agree with what rburke said on 6/5/23. It's clear that the leader line is automatically snapping to a point on the text bounding box (see below), but either the way the system decides which point the line snaps to needs to be improved or users should be able to specify which anchor point it goes to (I prefer the latter). In its current state, sometimes I would have to place the text in a weird location far away from the feature to get the line to point to the text in the way I want.
Wild that this idea has been "open" for over a decade!
WendyHarrison
Status changed to: Closed
Closing this one out as the original idea is offered in ArcGIS Pro.  Further ideas can be logged separately
GISAdminSHN
@WendyHarrison when I use the Mid leader style instead of the Base leader style it still seems to be far too sensitive and grab corner basepoints rather than midpoints:
As shown here, the angle of the leader allows ELECTRICAL PANEL to stay on midpoint, but even a slight change from that apparent limit gets me the abomination that is PAD MOUNTED TRANSFORMER's base snapped leader. Is there a way to suppress base leader positions when using the Mid leader style? Thanks!
