Label or feature with hyperlinked webpage
3450
01-25-2011 09:14 AM
Status: Open
BradS
I would like to be able to create labels for a feature layer in ArcMap that hyperlink to webpages. I don't want an HTML popup box in this situation. I want to be able to see a label on my map (possibly underlined and in blue) that allows me to click on it, and immediately open my web browser at the hyperlinked webpage. This webpage hyperlink should be able to be based on an attribute field in my feature layer. The text of the label should come from a different attribute field. So, the label expression could use HTML code and look something like this:
<a href='http://www.google.com/' & [WEBPAGE_FIELD] & '>' & [TEXTLABEL_FIELD] & '</a>
The result should be a map with labels displaying the text from [TEXTLABEL_FIELD] with all (or some) clickable, sending the ArcMap user to a webpage based on the attributes in [WEBPAGE_FIELD].
Also, it would be useful to have something similar for the features in a feature layer in ArcMap. For example, I'd like to be able to click on a polygon, line, or point, and be hyperlinked immediately to a webpage (based on an experession similar to the label expression above). There should be an option for making each layer's clickable features appear highlighted or "normal" in the map.
In addition, when I export the map to PDF, I'd like these hyperlinks to work the same way in the PDF document, so anyone without ArcMap will still be able to link to the webpages.
4 Comments
JacquelineHamilton2
It would be really nice if in ArcPro, the hyperlinks attached to a text or image would automatically go directly to the hyperlinked content (url or internal document) instead of bringing up a pop-up and then having to click on the hyperlink. This capability was accomplished in ArcMap but  I don't see this option using ArcPro.  Is there any movement forward with this?
Trisarahtops
YES to this! I need this feature as well. We used it in ArcMap with a URL field in an Annotation. By using the link button, we could open a link with one click. Requiring a pop-up in ArcPro is cumbersome.
BillGrimm
Agreed!
KAKS
YES. I would love to be able to have my station labels in the map be hyperlinks driven by a label expression that leverages feature attributes such as the station name. Also, have these labels remain ‘clickable’ in the layout and the exported PDF. I would use these links to open to photos/datasheets in the same folder as the exported PDF (using relative paths), streamlining and simplifying the process of providing PDF map deliverables with associated folder of pictures and data. Would be SO helpful. Right now I can’t see a way to do this in Arcgis Pro without creating the labels in the layout as text boxes one at a time.  Attribute-driven hyperlinks are only available in the pop-up for the feature class, and these are only clickable in the map, not in the layout or exported PDF. I’ve been using 3rd party software to set up the labels as links in the pdf after export, but it’s tedious.
