Incorporate ArcMap GPS display options in to Pro
456
02-19-2024 03:57 AM
Status: Under Consideration
DamianGrady
New Contributor II
Since moving from ArcMap 10.8 to Pro 3.2 the GPS display functionality is very limited. Would it be possible to have access to the following options in Pro for use on aerial surveys
In Pro we have the following problems: -
1        The symbol for the GPS location is very small and difficult to see against a busy map background. There does not appear to be an option to change the symbol size and colour.
2        There are no options to create an active trail for where you have flown as you can in ArcMap.
In ArcMap there were options to alter the display of live GPS data without the need to create a feature class.
Below are screen shots of the ArcMap options we would like to have access to in Pro.
Here is a simplified example of what a flight trace looks like in ArcMap
3 Comments
TanuHoque
SeaRM
See XTools Pro Add GPX if it can help. It allows adding GPX files to map directly as layers, so you can change feature symbology as you need, and also use time slider to see a flying process.
RobbieRotten
As someone who uses the GPS function in ArcGIS Pro on a field portable tablet the trail and symbol modification options are a neccessity. The reduced field functionality is a shame when compared to ArcMap and Field Maps is not a suitable stand in.
