Include singlepart statistic options when dissolving in ArcGIS Pro
1399
10-28-2025 05:57 PM
Status: Under Consideration
LindsayRaabe_FPCWA
MVP Regular Contributor
So, somehow I've managed to survive for years without coming across this issue....until now! The Statistic fields in Dissolve and Pairwise Dissolve do NOT honour "Create multipart features" option in these tools.
If you leave "Create multipart features" unchecked, and are dissolving 3 polygons where 2 are adjacent and a 3rd is not adjacent and all contain an ID value to be concatenated as a Statistic field (e.g. A and B adjacent with C not adjacent), instead of producing 2 output polygons with a statistic fields that shows (polygon 1) A/B and (polygon 2) C, you get 2 polygons but both contain A/B/C in the concatenated field (as if they were a multipart polygon)!
Visual example below (more reading here too).
IDEA: Include an option (second checkbox or other method) to control whether the statistic fields should be calculated as per the singlepart output or original multipart functionality. Bonus points if it's enabled by default!
P.S. Please update the documentation and tool tips of these tools to clearly state how these things work!
3 Comments
LindsayRaabe_FPCWA
From the linked post:
We are actively working on a solution for this using the PairwiseDissolve tool.  Our goal is to have it available in ArcGIS Pro 3.7.
Ken
MargaretCrawford
LindsayRaabe_FPCWA
@MargaretCrawford
If it's only "Under Consideration", does this mean it won't be in 3.7 as previously indicated?
