Include "Search Table" option for 'Table Attribute' Dynamic Text Source Table
1004
02-16-2025 09:44 PM
Status: Open
LindsayRaabe_FPCWA
MVP Regular Contributor
Existing functionality: Currently, when you insert an "Table Attribute" dynamic text element into a layout in ArcGIS Pro, you set the input source to a table (layer) in a single map frame and can filter the values to return by changing the "Query" from 'All rows' to 'Visible rows' or 'Custom query' (SQL Expression).
IDEA: Add an new 'By search table' option to the "Query" list that lets you filter the available rows using a spatial relationship with another layer (with X units of another feature/s).
USE CASE: I have many scenarios come up in my map production where we try to minimise the amount of manual input required by our users over elements in the layout. This feature would hopefully enable us to perform search between 2 layers in the map, so that a focus feature set by a definition query or map series (e.g. a Plantation) can be used to select one or multiple intersecting features from another layer (e.g. Local Government Authority) to then display on the layout. In the image below, it would return only features "A" & "P" (with a 100m search distance) instead of All rows (A-Z) or Visible rows (A,M,P & Z) from the grey layer.
This would be a relatively simple tool to use with similar functionality to Select by Location or any number of other tools that use an input layer and search distance parameters.
3 Comments
TanuHoque
@LindsayRaabe_FPCWA
What you are asking is from the layout side and I hope someone from that team will chime in.
I just wanted to mention that currently the following Idea is in the production plan.
https://community.esri.com/t5/arcgis-pro-ideas/spatial-definition-query/idi-p/922663
Will setting this at the layer level work for you? Or for your workflow you need to have it in the layout?
TanuHoque
Status changed to: Open
LindsayRaabe_FPCWA
Hi @TanuHoque Interesting concept. I hadn't come across that idea yet. I think Spatial Definition Queries could definitely achieve this in many scenarios, but not all. Where we don't really need to see the layer but just a list of attributes in the layout, then the Spatial Def Query would do the job. Other times though, we would want the full layer to be visible for situational awareness plus a list of attributes from features within the target zone.
