Include core functionality for all time zones
2472
6
10-19-2021 08:10 AM
Status: Closed
AJRStuart
It would be great when 'Publishing a Web Layer' in ArcGIS Pro that when  you configure the web layer and select a Time Zone for the Date Fields that all time zones that are listed all execute in the same manner.  Yukon has a fairly new time zone, and although it appears in the list of selectable time zones, when selected geoprocessing fails.  If any other time zone is selected the layer publishes as expected.
If the time zones are read from the local machine then it would be great if they all participated equally when selected.  If the time zones are from an installed system file then it would be great if all time zones were kept up to date.
Thank you!
6 Comments
SusanTran
Thanks, we'll take a look at this possible bug.
SusanTran
@AJRStuart  I took a look at this and couldn't reproduce a problem publishing with the Yukon time zone. This is supported and is working on my system.
Please reach out to Support if you're still seeing an issue. Thanks for posting.
AJRStuart
Thanks for your prompt reply. I did go back and do some more testing and after upgrading my ArcGIS Pro was successful in publishing using the Yukon Time Zone. However, I found that I can successfully publish a layer using the Yukon Time Zone if it does NOT have a date field in it. When I try with a layer that does include dates I am still unsuccessful at publishing. I'm curious if the data set you tested did include a date field or not.
Thanks again, I really appreciate your attention with this.
SusanTran
@AJRStuart Yes, I tested with date fields.
AJRStuart
When I check the ArcGIS Server logs I see the following error:
"Failed to create the service.: Failed to execute. Parameters are not valid. ERROR 000800: The value is not a member of UTC | Dateline_Standard_Time | UTC-11 | Aleutian_Standard_Time | Hawaiian_Standard_Time | Marquesas_Standard_Time | Alaskan_Standard_Time | UTC-09 | Pacific_Standard_Time_(Mexico) | UTC-08 | Pacific_Standard_Time | US_Mountain_Standard_Time | Mountain_Standard_Time_(Mexico) | Mountain_Standard_Time | Central_America_Standard_Time | Central_Standard_Time | Easter_Island_Standard_Time | Central_Standard_Time_(Mexico) | Canada_Central_Standard_Time | SA_Pacific_Standard_Time | Eastern_Standard_Time_(Mexico) | Eastern_Standard_Time | Haiti_Standard_Time | Cuba_Standard_Time | US_Eastern_Standard_Time | Turks_And_Caicos_Standard_Time | Paraguay_Standard_Time | Atlantic_Standard_Time | Venezuela_Standard_Time | Central_Brazilian_Standard_Time | SA_Western_Standard_Time | Pacific_SA_Standard_Time | Newfoundland_Standard_Time | Tocantins_Standard_Time | E._South_America_Standard_Time | SA_Eastern_Standard_Time | Argentina_Standard_Time | Greenland_Standard_Time | Montevideo_Standard_Time | Magallanes_Standard_Time | Saint_Pierre_Standard_Time | Bahia_Standard_Time | UTC-02 | Mid-Atlantic_Standard_Time | Azores_Standard_Time | Cape_Verde_Standard_Time | GMT_Standard_Time | Greenwich_Standard_Time | Sao_Tome_Standard_Time | Morocco_Standard_Time | W._Europe_Standard_Time | Central_Europe_Standard_Time | Romance_Standard_Time | Central_European_Standard_Time | W._Central_Africa_Standard_Time | Jordan_Standard_Time | GTB_Standard_Time | Middle_East_Standard_Time | Egypt_Standard_Time | E._Europe_Standard_Time | Syria_Standard_Time | West_Bank_Standard_Time | South_Africa_Standard_Time | FLE_Standard_Time | Israel_Standard_Time | Kaliningrad_Standard_Time | Sudan_Standard_Time | Libya_Standard_Time | Namibia_Standard_Time | Arabic_Standard_Time | Turkey_Standard_Time | Arab_Standard_Time | Belarus_Standard_Time | Russian_Standard_Time | E._Africa_Standard_Time | Iran_Standard_Time | Arabian_Standard_Time | Astrakhan_Standard_Time | Azerbaijan_Standard_Time | Russia_Time_Zone_3 | Mauritius_Standard_Time | Saratov_Standard_Time | Georgian_Standard_Time | Volgograd_Standard_Time | Caucasus_Standard_Time | Afghanistan_Standard_Time | West_Asia_Standard_Time | Ekaterinburg_Standard_Time | Pakistan_Standard_Time | Qyzylorda_Standard_Time | India_Standard_Time | Sri_Lanka_Standard_Time | Nepal_Standard_Time | Central_Asia_Standard_Time | Bangladesh_Standard_Time | Omsk_Standard_Time | Myanmar_Standard_Time | SE_Asia_Standard_Time | Altai_Standard_Time | W._Mongolia_Standard_Time | North_Asia_Standard_Time | N._Central_Asia_Standard_Time | Tomsk_Standard_Time | China_Standard_Time | North_Asia_East_Standard_Time | Singapore_Standard_Time | W._Australia_Standard_Time | Taipei_Standard_Time | Ulaanbaatar_Standard_Time | Aus_Central_W._Standard_Time | Transbaikal_Standard_Time | Tokyo_Standard_Time | North_Korea_Standard_Time | Korea_Standard_Time | Yakutsk_Standard_Time | Cen._Australia_Standard_Time | AUS_Central_Standard_Time | E._Australia_Standard_Time | AUS_Eastern_Standard_Time | West_Pacific_Standard_Time | Tasmania_Standard_Time | Vladivostok_Standard_Time | Lord_Howe_Standard_Time | Bougainville_Standard_Time | Russia_Time_Zone_10 | Magadan_Standard_Time | Norfolk_Standard_Time | Sakhalin_Standard_Time | Central_Pacific_Standard_Time | Russia_Time_Zone_11 | New_Zealand_Standard_Time | UTC+12 | Fiji_Standard_Time | Kamchatka_Standard_Time | Chatham_Islands_Standard_Time | UTC+13 | Tonga_Standard_Time | Samoa_Standard_Time | Line_Islands_Standard_Time. Failed to execute (ConvertTimeZone)."
KoryKramer
Status changed to: Closed
As stated in an earlier comment, the development team was not able to reproduce this issue. Please work with Technical Support if the issue persists.
