In list by source TOC, include feature datasets as a nesting level
1808
11
01-13-2023 12:00 PM
Status: In Product Plan
wayfaringrob
Honored Contributor
Right now if you have feature classes that live inside a feature dataset in your map, the TOC does not reflect this. It shows the .gdb as the overarching container and displays the feature classes as if they live right inside the .gdb. This is misleading; the tree should reflect the actual lineage of the feature classes.
Tags (1)
11 Comments
MDBowser
Displaying feature datasets in the table of contents data sources tab (and listing the layers that are sourced from each) in ArcMap was very useful.   This is missing from Pro, which requires you to go into the layer properties to determine this.  Is there a reason for this missing functionality or an oversight?  Would love to see this in a future version.
ArcMap:
ArcGIS Pro: (note there are 3 different feature datasets sourcing these layers)
GregoryLund2
GREAT Point(s).
It has been nearly 8 months since your post/question with 6 'Kudos', yet no-one from Esri has replied?
Seems as though showing the Feature Dataset in the Path would be a simple fix for Esri, or, as you noted, the ArcMap way of showing it as a hierarchical tree.
As it exists, ArcPro 3.2.2 (I wait a few months before 'signing up to be a crash test dummy' and upgrading to the latest version) is confusing and misleading (as @wayfaringrob and @MDBowser have mentioned.
Any idea of when/if this will ever get any traction?
btw, it would also be nice to be able to 'Clear the Projection' of a Map in ArcPro as well, but that ship seems to have sailed and is too complicated to achieve.
Evelyn_Chanti
Commenting to give this some traction.  This is a pretty big oversight in Pro.
wheelerdan
Agree, it would be helpful to know what dataset feature classes reside in.
RTPL_AU
Show the Feature Dataset in the Table of Contents - Data Source View.
Currently it only shows the FGDB with all the FC underneath.
SSWoodward
Thanks for the idea,
This seems to be a duplicate of  "In list by source TOC, include feature datasets as a nesting level"
Would you give that idea a look and confirm that these two ideas are asking for the same functionality?  If so I can merge them to aggregate kudos.
RTPL_AU
@SSWoodward Yes. Please merge.
MyEthiopia
@SSWoodward To add to the post, when working on data from the sde with multiple layers from different feature dataset this functionality makes our life easier. Often the names of the features in the content tab would be changed so to make it more appropriate for publishing or preferences. If we could see the feature dataset it would make my life easier when trying to republish a similar service or work on a project someone else created before me or when revisiting my work. Most service have 6 or more layers.
EdiePunt
GregoryLund2
EdiePunt,
Thank you, this is exceptional news!
Side note: An 'Upvote' on posts/comments would be helpful, IMHO.
If I recall it was in the previous version of these threads, maybe not.
But, back to this topic!!! I'm excited to hear this news!
