In AGP 2.6.3, when creating a new FC, please implement functionality to import fields from shapefiles. This functionality is present in ArcMap 10.7.1. But in AGP, the import window only shows Tables and GDB FCs are eligible for importing fields. Without this functionality, users have to add the steps to import a shapefile to a GDB FC, then when we create a FC the fields can be imported.
BTW, I contacted Esri Tech Support, they were able to reproduce this functionality.
Hi @LuciaBarbato1, thanks for reporting this issue. BUG-000135668 has been logged. In the meantime, please see this page for workarounds.
Hi @KyleC, thanks for the reply. Create Feature Class geoprocessing tool is a good solution in the meantime.
Implemented in ArcGIS Pro 2.8.
See Ideas in ArcGIS Pro 2.8 and (1:58) in the video.
