Import Domain from Another Geodatabase
14638
12
04-15-2014 01:19 PM
Status: Implemented
mpboyle
Honored Contributor
I think there should be a way to import a domain from another geodatabase rather than having to export the domain to a table and then import that table to a domain.  One step, instead of two should be required for this.
12 Comments
ReidSutton
The easiest way I have found to accomplish this is to copy an existing feature class with the desired domains and past it into the new geodatabase (in the catalog pane).  This will automatically import the domains into the new feature classes that you have created in that geodatabase. Then delete the pasted feature class.
MarcelBeckmann
Meanwhile it is possible to just copy and paste the domains in ArcGIS Pro.
Just open the domains view (right click on geodatabase --> Domains) of both geodatabases. There you can right click --> copy and right click --> paste the domains.
Even multiple domains at once.
