IDEA: Implement natural sorting in text fields throughout ArcGIS Pro (attribute tables, dynamic table elements, etc).
USE CASE: When sorting numerical values in ArcGIS Pro, if these values are in a text field and are sorted in ascending order, it puts any number starting with a 1 (i.e. 101) before any number starting with a 2 (i.e. 20). I know I could add leading zero's to the numbers to get more accurate sorting, but I don't want to have to do this to then have to remove them in labelling (or to educate others to do this).
It would be better if text sorting treated numbers holistically (or at least up to the point that a non-numeric character occurs).
Note - in below dynamic table element examples, sorting is done on the Rate column first then the Block column.
I know it's better to store numbers in integer type fields, but in the above use case, blocks could be labelled with alpha delineators as well:
1A, 1B, 5, 2, 9, 3, 4A, 4B, 6, 7, 8, 10, 11A, 11B
...and I would want these to sort to match the numbers first then the letters (logically) and not end up with 9 after 11A and 11B:
1A, 1B, 2, 3, 4A, 4B, 5, 6, 7, 8, 9, 10, 11A, 11B.
Currently these values would sort like this:
10, 11A, 11B, 1A, 1B, 2, 3, 4A, 4B, 5, 6, 7, 8, 9
I might be a good idea to rename your idea to
"implement 'natural sort' for text fields"
This comes up a number of times, eg.
@DanPatterson Thanks for the tip - I've made some edits to the post and title to better describe the request.
This is very, very desirable. In my view, the goal is to be able to sort a field/column as desired with no coding or manipulation (like padding), throughout the entire platform.
Upon a right click (and throughout all interfaces and API functions), there should be options to sort
Numerically
Alphabetically
Naturally
(similar to FME)
The natural sorting is such a common expectation and source of frustration for end users, and it seems unreasonably difficult to achieve for data designers - especially those with no coding skills. "I have to know code to sort this column 'correctly' ??? Or, I have to format it in a way that I don't want it to look??? It's just a sort!! ". Explaining why it's not that easy just doesn't land with most end users, any level.
With the increasing integration of GIS and enterprise asset management systems, many organizations are storing unique asset IDs in their GIS feature classes. These IDs are often alphanumeric, consisting of a letter prefix followed by a numeric suffix (for example: AB123, GV5, or XYZ9283).
Currently, these fields are typically stored as text, which means they sort alphabetically rather than numerically. As a result, values are ordered like this:
GV1, GV10, GV11, GV100, GV2, GV20, GV22...
instead of the more intuitive:
GV1, GV2, GV3, GV4, GV5...
This makes it more difficult to browse records, filter data, verify asset inventories, find the last used ID, and quickly identify missing or out-of-sequence IDs.
It would be extremely useful if ArcGIS supported natural (alphanumeric) sorting for text fields, where consecutive numeric characters are interpreted as numbers rather than individual text characters. This behavior is common in many file explorers, databases, and software applications, and would significantly improve the usability of alphanumeric asset IDs without requiring users to redesign their numbering schemes or maintain separate numeric sort fields.
For organizations managing thousands of assets across multiple feature classes, this would be a meaningful quality-of-life improvement with broad applicability.
related idea regarding Natural Sort
Implement natural sorting of text fields (numbers ... - Esri Community
