Identify features referenced by domain
626
06-23-2015 07:52 AM
Status: Open
BrianPangtay
Need to add a tool in ArcToolbox to identify features that use a particular domain.
This is tool would compliment the existing tools: Delete Domain and Remove Domain From Field since this information is required to use these tools.
I was provided with a Python script to accomplish this task:
import arcpy
import string
from arcpy import env
import os
#Set workspace environment to geodatabase
arcpy.env.workspace = r"Database Connections\Connecting to database.sde"
#Get list of feature classes in geodatabase
FCs = arcpy.ListFeatureClasses()
#Loop through feature classes in list
for FC in FCs:
    #List fields in feature class
    fields = arcpy.ListFields(FC)
    #Loop through fields
    for field in fields:
        #Check if field has domain
        if field.domain != "":
            #Print feature class, field, domain name
            print FC, field.name, field.domain
