There must be grouping for maps and layouts in the catalog pane
I had over 70 maps and 150 layouts across 11 areas, and it would have been very helpful if I could group them. Grouping would make it much easier to organize maps and layouts, similar to how layers are organized in the Contents pane. It could also be extended to databases and notebooks when working with large volumes.
This is a good idea, I too would like to be able to group maps into a "folder" under the Maps node in the Catalog Pane. As a use case scenario I am mapping the output of a tool called Tuflow. I have multiple rasters for different scenarios. It would help with organising the many maps I need to create which become map frames in a layout. Grouping them in some way would be very helpful.
