GP Tools — Disallow null shape, null geometry, and nil geometry where applicable
1207
05-22-2024 08:20 AM
Status: Closed
Bud
Legendary Contributor
It seems like some GP tools behave unexpectedly when there are rows with null shapes, null geometries, and nil geometries.
For example, BUG-000122441 - Dissolving a line feature using the 'Unsplit lines' option causes ArcGIS Pro to crash if the data contains null geometry.
Idea: For tools that can't handle null shapes, null geometries, and nil geometries, throw an error instead of producing unexpected results.
3 Comments
BBicking1
Hello Bud,
the issue is already addressed.
If you encountered the same issue in 3.3 and it consistently reproduces, please log a Support issue with detailed repro steps and data, so we can investigate. Make sure to hit Send report so we receive the crash report with crash dump file.
MargaretCrawford
Status changed to: Closed
Hi @Bud, as mentioned above the specific bug you included has been fixed since Pro 2.7.
But if you are getting unexpected results you could try to run Check Geometry on the feature class to find any problems, then Repair Geometry to correct the problems if needed.
Also, as previously discussed, development cannot provide sweeping fixes that address how all geoprocessing tools handle problems with data quality. If you are getting a crash or an Error 999999 we want to hear about the specific tool and reproducible case. So, please log this as a BUG with Esri Support. I am going to close this idea.
Bud
Note: Those tools don't support ST_Geometry, which is the datatype I use (Oracle).
