Go To XY button at bottom of map
254
04-22-2024 01:00 PM
Status: Open
Bud
Honored Contributor
ArcGIS Pro 3.2.2
When I want to go to a lat/long coordinate in the map, I intuitively look for the Go To XY button in the toolbar at the bottom of the map. It takes me a minute to realize that it's in the Map ribbon tab, not in the map, especially if I have a different ribbon tab open.
I'm wondering if it would be more intuitive to have a Go To XY button at the bottom of the map that is visible regardless of what ribbon tab is open.
2 Comments
SarahLeRoux
While not at the bottom of the map, you can add it to the quick access tool bar. Then it could be visible from any ribbon.
SSWoodward
 If you'd like to make the go to XY button present regardless of the active ribbon, it can be added to your quick access toolbar as mentioned by @SarahLeRoux
I also tend to use the setting to "show quick access toolbar below the ribbon" to keep my shortcuts closer to the map for ease of access.
GUID-2C9FBF62-CCA7-422C-AD84-6C4D2B3776C1-web
